hevi
Ace
Issue, hide selection and design options
Running AC27 27.1.1 on Windows 10
I'm experiencing an issue where if some elements in the main model or a design option is hidden using the hide selection command in the 3D view and then another design option is activated some of its elements will be hidden while some will be shown.
I have been able to reproduce it in the default template file but not consistently - sometimes it doesn't happen, sometimes it's different elements that is shown/hidden. The first thought was that it is just the flawed implementation of hide selection that is at play as the view as the view remain limited by selection but then there should be consistency in that none of the elements of the activated option should be shown. Instead it can be one element in one option and all elements in another option.
It's quite weird and feels like there is some cross wiring between elements that should be independent as they are in different design options. Anyone else experiencing this and have figured what additional thing we need to keep track of for correct views?
0 Replies 0
