Visibility of Wall Lines at Corners
Hi all - I am having strange thing happen where the ends of my walls seem to not have the same line weight as the wall itself - not sure if I hit a setting or what is causing this...I highlighted it in purple in the screenshot. Thanks so much for any help!
1 Solution
This post should explain what is happening.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=62618
Basically you have to activate the skin end lines in your composites and set the pen colour to the same as the skin lines.
Go to post
That did it thank you Barry!
