Wall Dimensioning
dhnguyen
When I dimension the length and width of a room, ArchiCAD automatically dimensions the wall thickness as well in addition to its length or width.... I am constantly selecting the wall thickness and deleting it--- how do I turn off this feature?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Assuming you are still using version 18 as in your signature, that is probably because you are clicking on the edge of the wall.
Click on a node at the end of the wall or a corner instead and you will get just the one dimension point.
Or as you click on the wall edge and you get the 2 dimension indicators (the little target symbols), you can click on the one you don''t want and it will delete.
You don't have to place the dimension and then edit it.
I don't recall a setting in 18 to dimension just the one edge of a wall.
However, if you are using version 22 there are a few new dimension options, one of which will allow you to do just what you want.
dhnguyen
I see, thank you!
DNguyen
ArchiCAD 18- 25
