Wall Pens Wrapping Incorrectly with Current Release
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-01-27
07:55 PM
‎2024-12-30
03:42 PM
Molinda Prey
- Labels:
Graphic Overrides
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-28 08:02 AM
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-28 04:54 PM
Thanks for your reply. Changing the material fill pen to "Pen 7" solves the issue at outside corners but creates a similar issue at interior corners (see attached). After my last post, I reinstalled Archicad 22 with the previous version and the problem stopped. This bug could be tied to the new incremental drawing feature as there were several improvements made regarding this feature in the most recent update. Regardless, this is a problem Graphisoft needs to fix before I will update again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-28 04:56 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-28 05:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-01-28 05:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-06 02:24 PM
Just want to clarify the situation, so you are not in doubt. There was a feature included in the first update of AC22 (build 40xx) that made the skin connections more realistic, following the rules they have been connecting in 3D for years. Reinstalling solved your issue because in the released version without the update (build 30xx) this is not implemented yet. This issue is further explained and debated in this other topic:
Thanks for the pictures and the explanation of your workflow. We are working on fixing/fine-tuning this feature, and this input is very valuable in that (this is a legit use case that wasn't taken into account). If I have further information about this, I will post to the other Topic.
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-06 04:59 PM
Thanks for your response and clarification on the issue. Balancing the realistic construction with the graphic representation can be a troublesome issue. One possible resolution would be implementing a graphic override similar to the complex profile override which gives a uniform pen to the object's profile or "air line". I am unsure how difficult a feature like this would be to add, but it would simplify a lot of aspects in both plan and section.
Thanks again for your response.
Chris
