Wall line between windoes
I wish to remove the line between windows on plan, which we used to achieve in 18. How do i turn this off in 20?
Thanks
3 Replies 3
David Maudlin
James:
Try the Ganging function, in the USA Library it is at Window Settings > Fixtures and Fittings...
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you David,
Ive scrolled through the settings a thousand times and managed to miss it!
Problem solved!
Thanks,
James
David Maudlin
James:
Glad that worked, thanks for posting back and adding your signature.
