What is the best way to insert details into an ArchiCAD proj
I am starting to build a fairly extensive library of detail drawings that I have drawn in ArchiCAD. Right now I have each detail drawn in separate PLNs. Up until now I have opened each detail drawing PLN so that I can copy and paste the detail drawing into each new ArchiCAD project. This doesn't seem like it is the best way to do this.
What is the best way to insert previously drawn details into an a new ArchiCAD project?
10 Replies 10
For years I have inserted previously drawn details into
a project by saving the individual detail drawings as
modules (.mod) files then when I need to insert a detail
I use the merge command from the file menu. No need
to open another project and copy and paste. I keep all
the module files in one folder.
Peter Devlin
Peter Devlin
Aloha Peter,
How does merging modules differ from importing a drawing via "File > External Content > Place Drawing"?
After asking my question I have been experimenting with the import method and it seems to be working. Using the import routine also gives me the ability to directly open the original PLN.
Thank you,
John
Hello John,
The difference seems to be that you can only place
image files that are not editable in Archicad.
Merging either a module or a whole project inserts Archicad
elements into the project. These elements are editable.
The modules I use are standard details made with
lines, fills, text, dimensions, and lib parts that are all editable
in the project since there's no such thing as a "standard detail".
Peter Devlin
See THIS for a good tutorial on detail libraries.
Richard
AC26 (since AC6.0), Win10
You can also save Views of those details in the other file and simply place those external Views onto your Layouts by drag-and-drop in the Project Organizer Window of the Navigator. They will be placed as Drawings on the Layouts.
Of course, this is good only if you do not need to modify anything in those details.
Aloha Laszlo,
Please explain how to do this.
I have the two projects open side by side. In the detail.pln I have saved a view of the detail that I want to show in the project.pln. I've tried to drag and drop the view of the detail from the detail.pln to the project.pln but I have not been able to drag it from one PLN to the other. Please explain how to do this.
Mahalo,
John
Kia Ora John
You do this in Organizer, with one file (detail file) open in the left panel, the other open in the right, as opposed to having two instances of Archicad open. Top left button in Organizer is called Project Chooser, click it then Browse to your detail PLN file. Then drag views from Detail file view map on left side, to appropriate Layout on right side.
Hope this makes sense.
What I am doing now is the compile all of my details in one master details.pln. Each of the details is saved as an independent detail in the detail.pln. When I want to use one of these details in an ArchiCAD project (project.pln) I use the File/External Content/Place External Drawing command to place the selected details directly onto one of the layouts in the project.pln.
I like working this way because I can use the "Open external source View" command to open the independent detail in the detail.pln. Once this is open I can modify the source independent detail so the detail keeps getting improved each time I work on it. Alternatively, if I want to make changes to the detail that will be unique to a particular project I can cut and paste the drawing elements of the detail into the project.pln. In this second case I could also create a new independent detail in the detail.pln so I have the new, unique detail as part of my detail library.
This system seems to work for me now but I would also like to get other user's feedback, improvements and tips on how they build a detail library for use in their ArchiCAD projects.
I would also like to know if this process can be streamlined by dragging and dropping the independent details directly from the details.pln into the project.pln.
Thank you,
John
I would still like to
s2art wrote:
Kia Ora John
Kia Ora Stuart,
That works great! Thanks for the tip. I like it a lot. You've shown me how to make this process much easier. I appreciate your help.
Mahalo,
John
