Geting Drawings in Ps without losing quality?
Hi all,
Im trying to put a section into Ps to arrange and add some things in, but when i publish as a Ps file the quality vanishes, does anybody know a way arround this?
And can you set AC up to publish as EPS file (like AutoCAD)?
Thanks
3 Replies 3
TMA_80
Hello !
Publish in pdf format..then open the pdf in PS.
AC12_27 |Win11_64bit|
Ended up just publishing as DWG and then ploting EPS from CAD, seems to give slightly better results due to it not having to rasterise. Thanks for the advice however.
Another option is to export as dwg bring dwg into Illustrator. You can control color and weight of lines very easy. Then it's a simple cut and paste into PS
