2010-03-19
08:54 PM
- last edited on
2025-01-28
12:02 PM
by
Aruzhan Ilaikova
2010-03-19 10:42 PM
2010-03-19 10:50 PM
Peter wrote:Aloha Peter,
For years I have inserted previously drawn details into
a project by saving the individual detail drawings as
modules (.mod) files then when I need to insert a detail
I use the merge command from the file menu. No need
to open another project and copy and paste. I keep all
the module files in one folder.
Peter Devlin
2010-03-20 12:41 AM
2010-03-20 04:37 PM
2010-03-22 12:48 PM
2010-03-22 07:31 PM
laszlonagy wrote:Aloha Laszlo,
You can also save Views of those details in the other file and simply place those external Views onto your Layouts by drag-and-drop in the Project Organizer Window of the Navigator. They will be placed as Drawings on the Layouts.
Of course, this is good only if you do not need to modify anything in those details.
2010-03-22 09:17 PM
2010-03-22 09:20 PM
2010-03-22 10:18 PM
s2art wrote:Kia Ora Stuart,
Kia Ora John
You do this in Organizer, with one file (detail file) open in the left panel, the other open in the right, as opposed to having two instances of Archicad open. Top left button in Organizer is called Project Chooser, click it then Browse to your detail PLN file. Then drag views from Detail file view map on left side, to appropriate Layout on right side.
Hope this makes sense.
