White Background for Fills
Hello, I am having an issue with my fills. I want my stacked stone fill to have a white background instead of a grayish background. However, I do not see an option to change this in its setting. I am using a surface on a wall that has the stacked stone fill as its hatch. What should I do to fix this. Attached is a photo of a wall with the stacked stone surface. I have also attached photos of the settings for the stacked stone fill as well as the settings for the surface I am using with the stacked stone hatch. Thanks for your help.
2 Replies 2
Dave Seabury
Stephen
open your elevation or section marker and look under model display
and see if the surface pen is something other then white.
Just a thought
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Eduardo Rolon
In AC when you place a Fill or line with the same color as the background it changes it so that you can see it. It will print correctly. Check under Options-> Work Env -> On Screen Opt-> Automatically Pen Color Visibility…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
