Window Labels - all windows have same ID
Probably a beginner error
I created some window favorites, but now that I have placed several of them they all have the same window ID even though they're different sizes. Is there a way to re-sequence my window and door IDs?
What should I have done different when saving the window favorite so when I place a new one it gets a new ID?
Marc
6 Replies 6
If you keep selecting from the list of favourites they will have the same ID as all settings are kept.
You can select windows in the order you want to number them then go to Document (menu) > Schedules and Lists > Element ID Manager to sort ID's. I have had varying results with this, though, but have not had to use it for a while - bugs may have been sorted out.
Thx a lot - I tried selecting in sequence but it did not rename in sequence. So just ended up with the manual renaming, but thx for the guide to the ID manager - did not know that.
Unless you tell Archicad to ignore the ID by ticking the ID box for windows/doors then you will get a new ID each time you place a window.
It probably still won't be what you want so either manually change it or use the ID manager as Stuart suggested.
The attached image is for something similar but you need to go into the windows/doors section and tick the ID box.
Awesome - Thx Barry. This is exactly what I was looking for. Unchecked the ID tick box for windows and now the favorites auto sequence from the number i start from.
Hi, Just to add a little bit here.
The way I set the ID to the windows is a very quick way, but only if you don't mind which one is W01 or W02 etc... (because I still don't know how to tell archicad which window should be the W01) For this I use the Element ID manager and ask to Change ID by criteria as shown in the image below, and AC does it automatic. You can set any criteria you need. And in the ID Format Tab you can set whichever format you want.
BTW someone needs to teach to the spellcheck how to spell archicad
I am also use of manager but same size window show different I'd how can I change this ?
