jake_h03
Window MVO and graphic override issues
Hi, I'm having some issues getting windows to show the way I want them.
I am exporting masterplans at 1:300, and the window is reading solid when the glazing is shown, so I want to turn this off. I can do this through model view options, but this doesn't seem to work for curved windows. All curved windows still show the glazing line. However if I put the same curved window on a straight wall, it shows correctly. I'm guessing this is just a bug an archicad. Is there any other way to show curved windows with no glazing line? Maybe through model view options?
Now without the glazing line, the window just looks like a low height wall, so I want to show the mullions with a solid cut fill to clearly show the window frame. However, it only shows the outer frame, not the intermediate mullions created with the H-V Grid sash. The only way seem to be able to show the intermediate mullions is by switching the Floor Plan Display to projected rather than symbolic, but then the Model View Options has no effect and I can't hide the glazing line at all.
Essentially, I want all windows (including curved windows) to show with all mullions as a solid cut fill and no glazing line. Surely this is possible?
Any help appreciated
Operating system used: Windows 10
Could you show a few screenshots?
