Window & Door Dimension Marker on Elevations & Secti
How do I get the Window and Door Dimension Marker that is showing on the Floor Plan, to show on sections and elevations?
Is there a general setting for this or is it something that has to be built in into the library part itself?
AC 9, P4, Win XP,
3 REPLIES 3
I am afraid you have to get a window/door that is programmed this way.
AC 9, P4, Win XP,
I use the label tool with the window label-marker and use the ID as my window ID. It may not be what you are looking for but perhaps it will give you what you need.
TomWaltz
You can also use the Label tool to do this. It just isn't automatic.
Tom Waltz
