Window and Door Marker Orientation Fixing
In my Archicad Floor plan- Door & Window markers are in different orientation. But I need them all in marker at a single orientation. Can you please check the issue and give a solution?
Here is the Screen Shot in the attachment.
GREAT ......THIS IS THE SOLUTION I WAS LOOKING FOR.
SIMPLE & PRECISE
THANKS A LOT .
5 REPLIES 5
Hello avishiplu,
Do you try to use windows and door Labels instead of windows and door Markers ?
I do not use Markers since Labels creation. 😕
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
In case the Door/Window is placed into a vertical wall, the Text should be looking to the left.
In case the Door/Window is placed into a horizontal wall, the Text should be looking upward.
So, if you have a Door/Window in a vertical Wall, and the Text is looking to the right, the first thing I would check is whether that Wall is really vertical. If it leans towards the left just a tiny little bit, then the Text will look to the right.
Christophe wrote:
Hello avishiplu,
I do not use Markers since Labels creation. :/
I didn't use the Labels yet. Actually I heard about it from ur comment. Thank you. Can you please explain why I should use Labels instead of Markers.
And if possible please guide me to use Labels . I dont know how to use it.
Hello avishiplu,
There is different kinds of labels. One of them is called "Door Window Stamp"
You are able to link this label to your windows and doors like marker but labels are on a layer you can hide.
It really easy to use and it will give you some idea about using labels in other aims.
Christophe - FRANCE
SIMPLE & PRECISE
THANKS A LOT .
