Window/door labels in elevations
I downloaded the update that was released accidentally and since then I cannot get the labels to show in elevation view, has anyone else had this?
1 REPLY 1
So you select the Door or Window in the Elevation Viewpoint, then check the Label Elements checkbox and the Label doesn't appear? Not even its Leader line, nothing?
