Windows outside wall frame on Interior Elevations
Any idea why these windows are showing outside frame on Interior Elevations? Wall is Complex Profile and it shows fine on plan.
1 REPLY 1
If the window is set with a 'Symbolic' floor plan display, then it may not match the location of the frame in 3D when used in complex profile walls.
This may help to illustrate the problem (or it may just confuse it more).
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=62812&p=288044&hilit=symbolic#p288044
I still haven't worked out a solution.
Try adjusting the opening reference line position in the complex profile or use 'Projected with Overhead' as the floor plan display for the window.
