Zone fill does not appear correctly
Hi everyone
Here is a problem I'm having in AC22. See image below.
In short the zone fills only show up within walls - and not in the room itself. Note these are light coloured screen fills and typically will show anything in front or behind.
No graphic overrides, no SEOs.
How can I get the zone fill to show up normally?
Thanks
2 Replies 2
Hello emerich,
Do you try to put you zones behind ? Or all other elements in front ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Lingwisyer
Guru
Not quite sure what I am looking at, but I looks as if the line that draws your dishwasher is set as a zone boundary while none of your walls are...
