Zone in Section
Has anyone had success with the zone in section Add-On in Archicad 24? It does not show up under the design extras tab as indicated.
you can make an object and put that in front of your sectiion lane, when you attached with autotext label, write code that : #relatedzone , after you will receieve on the section and click with autotext it will show your zone in a section, when all done, you can hide that object created for it!
there is somevideo you can google it.
good luck
RandyC
The zone in section add on that is available in North America with Archiplus is only for
Archicad 23 it is not available for Archicad 24 - where have you found the Archicad 24 add-on ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
