SOLVED!
Zone label automatically centred on zone extents
tomyg
Hi all, just wondering if there is a way to setup the zone stamp so it automatically centres the text in the zone.
I can't seem to get it to work....
Archicad 25.
1 ACCEPTED SOLUTION
Solution
If you are using 25, make sure you have the latest update 2 (build 4013).
Instead of using zone stamps, you can now use labels.
They can be placed individually exactly where you want, or select all zones and then label all selected and the label will place exactly in the centre of the zone - in plans and also in section.
2 REPLIES 2
Solution
Perfect! thanks Barry
