Zone tool Perimeter/Dimensions
Chadi SAROUFIM
Working with the Zone tool and showing the perimeter. The perimeter unit is related to the one specified under the Linear Dimension in the Preferences. So if they are in mm the perimeter and the dimensions will show in mm. How can I have the perimeter in meters and the dimensions in mm.
Waiting for your feedback,
Chadi SAROUFIM
Architect - Partner
Idepconsult - Lebanon
www.idepconsult.com
Chadi Saroufim, Assoc. AIA
M. Arch & M. Urban Design, Partner
Idepconsult – Mounir Saroufim and Partners
ArchiCAD 23 INT
Windows 11
1 REPLY 1
Djordje
Dimensions units and precision are also saved with the view. Regardless of the units set in Preferences, you can override that setting by defining the appropriate dimension settings in the saved views.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
