Monday
- last edited
20m ago
Hi, we have developed a label to help with modelling tasks. It can automatically track the rotation angle of walls and beams, which is not available in any other interface at the moment. This allows several interesting workflows to check the alignment of elements, but also to label the orientation according to north or automatically display rotation angle with custom precision.
Check the video below for a quick demo of the features:
Tuesday
There are a few GDL labels like this floating around the community, but those are usually more like functional prototypes, and this looks like a much more polished and feature rich tool!
Very good job! Looks like a very useful tool!
Wednesday
Hi Jaime,
Firstly, this is a great tool to cross check wall angles...
I did install, however unable to make it work ? after adding the GSM file to the library, the angle tool is that some sort of settings or will that automatically show on all walls ?
I am using Arch 28
Thanks,
Caleb
Thursday
Hi Caleb, the free version of the tool works only on walls (not as well on beams as the full version) and has all the advanced settings locked. It is a label, so in order to use it, you will need to it apply manually using the label tool or in bulk by using the command Label selected elements.
