Guillermo1
anchor point of column
Hello, can we show the anchor point of columns in the floor plan?
Operating system used: Mac Apple Silicon sonoma
1 Solution
Olivier-IDAO
Not possible at the moment, but be free to request it in the Wishlist...
Alternatively, here's a tip: Like the walls with the reference line, if you hover over the different points of the column your cursor is thicker when it is on the anchor point.
OL
Interior designer, Former & Bim expert
Archicad 6.5 to 29
MacStudio 2023 Apple M2 Max powered by MacOS Sonoma 14.7.4
Go to post
3 Replies 3
Olivier-IDAO
OL
Archicad 6.5 to 29
Guillermo1
Thank you Olivier, it would be great that we can see the anchor point on floor plan
ppumares1
Hi! We use complex profiles to do that. We have three types, because if we want the default cross in Archicad to mark the reference point, each one needs to have an origin: center, corner, and face center. It has other disadvantages, such as dimensions resetting when the profile is changed, but it is a workaround...
AC27
