black and white elevations
Is anyone able to explain if it is possible to change the hatch colour of an object (in this case it is a shed in the back corner of the site) in an elevation. I would like to change the shed to be a light grey because it is behind the house and not relevant. I can change the outline but not the hatch.
thanks.
Lingwisyer
Guru
The Marked Distant Area option to set it all to a uniform pen does not work?
Podolsky
Ace
Graphic Overrides is not working there?
You can change colours by having different pen set. This method is very old and very robust. Even AutoCAD is using it.
Let say pen set 'black', 'grey', 'monochrome'
Take a look how I've done it in my template:
https://archicad-talk.graphisoft.com/viewtopic.php?f=37&t=72947
