Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Display Storey lines on 3d...
Llian
What do I need to do to display the storey lines on the attached 3D slab floors?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
2 REPLIES 2
You can't annotate (text, lines, dimensions) in 3D.
Only in a 3D Document.
And there you will have to probably add the lines manually - it is not like a section or elevation where you can just turn the storey levels on.
Unless somebody has created an object that can do this - I am not aware of one.
Llian
Thanks Barry.
Now I know there is no built-in feature for this.
