Display Storey lines on 3d...
Llian
What do I need to do to display the storey lines on the attached 3D slab floors?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
You can't annotate (text, lines, dimensions) in 3D.
Only in a 3D Document.
And there you will have to probably add the lines manually - it is not like a section or elevation where you can just turn the storey levels on.
Unless somebody has created an object that can do this - I am not aware of one.
Llian
Thanks Barry.
Now I know there is no built-in feature for this.
