I felt this would be a great resource venue, even if the subject is seldom discussed. I
truly appreciate the input.
I cobbled this disclaimer together several years back and haven't really reviewed since. Reading and re-reading it is embarrassing
![](/legacyfs/online/emojis/icon_redface.gif)
. The language is that of someone who is scared to death to take responsibility for their work. That's not me or my intent..........My work is done on a handshake believe it or not. I came up working with a contractor building million dollar homes that way and have always admired, naively or not, that way of conducting business. To that end I am way off base with my original language. I sincerely doubt any of this, old or new version, could be defended against aggressive legal representation. It's not about that in so much as it's intended to compel participation toward the desired result without disregard for the parameters that guide local residential construction.
With your assistance this is where I'm headed. Hopefully appropriately defining who's responsible for what. Any further input is appreciated.........
THIS DESIGN AND PLANS ARE THE SOLE RESPONSIBILITY OF WHITECAP3D, [JEFF WHITE], AND HAVE BEEN GENERATED FOR THE CLIENTS LISTED IN THE PROJECT NAME AND ARE NOT TO BE USED, REPRODUCED, COPIED, OR DISTRIBUTED FOR ANY OTHER PROJECT WITHOUT WRITTEN PERMISSION FROM AND OR COMPENSATION DUE WHITECAP3D.
UTILIZATION OF THESE DOCUMENTS AND SUBSEQUENT FABRICATION-CONSTRUCTION ARE THE SOLE RESPONSIBILITY OF THE CONTRACTOR. BEFORE STARTING CONSTRUCTION THE CONTRACTOR SHALL REVIEW AND VERIFY ON SITE ALL DIMENSIONS, DETAILS AND THEIR CORRELATION TO ATTACHED ENGINEERING. ANY DISCREPANCIES IN PLANS, DIMENSIONS, NOTES, OR DETAILS SHALL BE BROUGHT TO THE IMMEDIATE ATTENTION OF THE DESIGNER PRIOR TO COMMENCING ASSOCIATED WORK, ALLOWING REQUIRED CORRECTIONS TO BE PERFORMED. ANY ATTACHED ENGINEERING OR LOCAL BUILDING AUTHORITY NOTATIONS SUPERSEDE AND OVERRIDE MATERIALS, FASTENING, NAILING SCHEDULES AND CONSTRUCTION PROCEDURES PRESENTED IN PLAN, SECTION OR DETAIL VIEWS AND SHALL TAKE PRECEDENCE OVER ANYTHING SHOWN, DESCRIBED OR IMPLIED. THE CONTRACTOR ASSUMES LIABILITY FOR ANY PROBLEMS THAT MAY ARISE DUE TO NON-COMPLIANCE. USE OF THESE PLANS CONSTITUTES COMPLIANCE WITH THE ABOVE TERMS.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
