curved roof and incline in wall
1 how do i create a roof slab which is partly curved ? (attached PDF with the section)
in relation to this, where does the wall ends and the roof begins ?
2 also, second question, is how do i create a banister (simple, wall-made) that is inclining with a staircase ?
i managed to do that with a mesh but i guess there is a better way ?>
thank you all in advance
Thomas Holm
Make complex profiled wall. Check the help file.
That's for you to decide. You may choose to make it all as one entity (complex profile wall) if you like.
Do a SEO (solied element operation) Use the staircase (or a roof on a layer that you hide) as operator, the wall as target, Subtract with upwards extrusion. See Help files.
