2009-05-14
05:37 PM
- last edited on
2023-06-07
03:07 AM
by
Gordana Radonic
2009-05-19 03:20 PM
laszlonagy wrote:I haven't though of pmks in awhile:) Maybe worth rethinking though. Just to make the point as above, I personally never set a detail to auto update, and have submitted it as a bug for the last 2 versions as being being "mandated" (when dragging from nav on to layout). It's ridiculous to need to select them to change the status. There needs to be a preference for that. I seem to get a point out of it, so there is some recognition, but no action. I have found the ability to easily update very helpful and really do appreciate being able to have my details in one file, however, my work is a bit abnormal, so different rule apply. As an example, I can have the same basic detail and easily generate several versions with layer management. As an example... any wall details, from the ground up can easily be set as a view with a 2x6 and a 2x4 version. Since all details are in one file, it is always open and quickly available when I open a pln. so I haven't noticed the 1000x freaking slowdown
PMK has the great advantage that it does not update if you do not update it, which is sometimes just what users want (like in archiving and stuff).
2009-05-19 04:40 PM
Rick wrote:A couple of things...
2009-05-19 05:16 PM
2009-05-19 08:30 PM
2009-05-19 08:41 PM
vfrontiers wrote:I don't know what GIGANIC is but agree that anything involving opening a 2nd copy of AC is too dang slow. All our stuff is on the corperate servers but I use Chronosync to mirror the data to my local machine to cut out network slowdowns. You need to be careful (particularly when working with others) but it is a system that works well for us. And Chronosync is a fantastic tool with uses far beyond this.
To be fair, my slowdowns likely have another contributing factor... the NETWORK... we're on GIGANIC, and it doesn't really seem to bog down, but still... opening up the 2nd file just sends AC into a tailspin.
2009-05-26 04:41 AM
2009-05-26 04:54 AM
another Moderator
2009-05-26 05:32 AM
2009-05-26 05:56 AM
another Moderator
2009-05-26 06:12 AM
