2009-05-14
05:37 PM
- last edited on
2023-06-07
03:07 AM
by
Gordana Radonic
2009-05-26 06:13 AM
2009-05-26 06:16 AM
another Moderator
2009-05-26 06:27 AM
2009-05-26 03:15 PM
Brett wrote:I don't get your point.
The reason I said definitely 12 for the observant one's
Yes thanks, but? I think I must be blind.Definitely AC 12 Publishing method "save"Which I took to mean that you cannot find that option in your publisher. Then I reread your signature and see that you are using AC11 which does not have this option so obviously you cannot use it and you confirmed that is the case.
Brett wrote:
Could someone please point me to the instructions for saving a view as a PMK in 12. I've looked in help and there is zero information for a "new feature".
Brett wrote:________
Been there,done that, but if you look at both those pages it says absolutely nothing about how to. I can't find anywhere in Publisher to save as PMK. Nothing under "Publisher Set Properties". Nothing under "Document Options"
another Moderator
2009-05-26 04:04 PM
2009-05-26 04:13 PM
another Moderator
2009-05-26 11:36 PM
2009-05-27 12:30 AM
2009-05-27 12:52 AM
