2011-12-12 04:45 AM - last edited on 2023-05-22 11:59 PM by Gordana Radonic
2011-12-12 06:26 AM
2011-12-12 07:46 AM
Barry wrote:TAB. That works. Thanks, that is part of what I was looking for.
If you are dimensioning on the end of a wall and there is more than one wall ending at that point then you can use the TAB key to cycle through all the available walls.
When the one you want to dimension is highlighted that is when you click for the dimension.Barry.
Barry wrote:When I do this I get three dimension points per wall. I get a dimension point at the end of the control line of the wall as well as dimension points at each of the two surfaces of the wall. I only want to dimension to the control line of the wall.
Otherwise just pass your mouse over the length of the wall you want and when you see the mercedes cursor click to dimension - this will give you the width of the wall with one click.Barry.
2011-12-12 07:54 AM
johncassel wrote:You can make it dimension just the "core" skins of the wall but unfortunately you can't make it dimension just the reference line.
Is there a setting so it only dimensions to the control line?
2011-12-12 08:02 AM
Barry wrote:There is a secondary issue here in using the Tab Key to cycle through the overlapping walls if I am extending an already existing dimension string. This gets particularly difficult because I'm holding down the Control Key to add the new dimension points and hitting the Tab Key starts to cycle me through the different view windows that are open. It kind of funny and kind of frustrating but this isn't the biggest problem that I am dealing with today.
2011-12-12 08:15 AM
Barry wrote:How do you make it dimension to just the core?
You can make it dimension just the "core" skins of the wall but unfortunately you can't make it dimension just the reference line.Barry.
2011-12-12 08:23 AM
2011-12-12 08:27 AM
johncassel wrote:In the dimension setting dialogue there is an option you can check.Barry wrote:How do you make it dimension to just the core?
2011-12-12 08:54 AM
Barry wrote:OK, you are my new best friend. Thank you very much for walking me through this.
In the dimension setting dialogue there is an option you can check.Barry.
2011-12-12 09:01 AM
