dimensions preference doesn't "stick"
I am trying to change my dimensions preferences so that my dimensions show trailing 0 inches, ie 8'-0" instead of 8' . I found in Objects>project preferences>dimensions that I can fix this with the radio buttons, and when I click "ok" it makes the changes in my active window. But when I rebuild the window or check any others, the dimensions have reverted to their previous setting.
What am I not doing, to make these changes "stick"? Thanks.
5 REPLIES 5
Srinivas
Make sure you apply those dimension preferences to your view map to make them stick.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
David Maudlin
jfanjoy:
Also, once you have the preferences set correctly in the Project Preferences > Dimensions window, name the Standard so it does not read as "Custom".
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AHA! I knew it must be something like that, I just didn't know where to look. Thanks.
nusha
I'm having the same problem. Seems like your solution works but (sorry for a silly question) how do I apply dimensions to the view map?
David Maudlin
nusha:
In the View Map, select the View, click on Settings, in the 2D/3D Documents panel change the Dimensions to your desired Standard.
