‎2006-09-22 12:51 AM - last edited on ‎2023-05-30 03:23 PM by Rubia Torres
‎2006-09-22 12:56 AM
‎2006-09-22 01:27 AM
Aussie wrote:I do not bother setting a temporary origin. with the wall tool selected, just hover over existing wall then type "x" (or y), the distance, then "+", and "enter". This will set the beginning of the new wall. If the distance in the x or y direction is into a Negative Quadrant (Left in the X direction & down in the Y the direction with Normal Orthogonal Grid) and you are using SI units you must hit the "-" twice instead of once, and then hit "enter".
You can put a temporary origin at the existing wall then type the start coordinate. of the new wall
I find it easier to duplicate the original wall and type in the distance to be away
‎2006-09-22 02:40 AM
Jay wrote:Why twice? Once works for me.
... you must hit the "-" twice instead of once...
Jay
‎2006-09-22 02:51 AM
s2art wrote:Are you one of the millions of lucky metric users?
s2art wrote:Never actually tested the Shift"=". Thanks for the heads up.
And be sure to use the "+" on the numeric keys, not the "+" you get with SHIFT "="
‎2006-09-22 03:06 AM
Jay wrote:Oh, its an imperial thing is it?
Jay wrote:What I meant was dont use the + symbol on the = key (which you get by using shift= on the main keyboard for general typing, not that you can use shift to get the + in this case, I'm pretty sure that doesn't work).
‎2006-09-22 03:43 AM
s2art wrote:it does. i do it all the time - my laptop doesn't have a dedicated numeric keypad . . .
‎2006-09-22 03:49 AM
bosoturk wrote:going back to the original question...
does anyone know if this thing is possible in archicad 10? it would be very helpful to know how far from right wall i'm building new one.
‎2006-09-22 04:31 PM
