alexliz24
Publisher's PDF server upload also sends Scratch files
I have successfully uploaded .DWG sets through Publisher.
Now I've upgraded to 987, and for the first time I tried to upload .PDF files. Initially they failed to go (unknown error), then I rebooted my Powerbook; now they upload alright, only so do some Scratch files together with a checksum.xml file.
What gives? I can manually go and delete those from my server, but that sort of defeats the object of automation, doesn't it?
Many thanks, folks.
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
4 Replies 4
Djordje
As discussed here, it is MacOS. Update it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
alexliz24
Hi Djordje,
As discussed here? Where?
BTW, my MacOS X is 10.4.5, and I am just about to update to 10.4.7 (current one). Java is up-to-date, which solved the Publisher's PDF issue (it used to produce Zero kB pdfs).
Alex Zachopoulos
Djordje
http://archicad-talk.graphisoft.com/viewtopic.php?t=12105
Djordje
HP Omen
alexliz24
Oh, _there_!...
It was Fra who pointed me in the direction of the Java update in the first place, pointing to that very thread.
So, then, this issue here is nothing to do with my Java update. In any case, I think it may have been a case of my Mac needing a restart. Now, it only sends a checksum file together with the .pdf files, but no scratch files.
Thanks for the posts all the same, Djordje!
Alex Zachopoulos
