Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
dimensions
i have to work on a project in METRIC.
i look into the preferences and the dimension settings and i can't find a setting to show
1000 and NOT 1,000. ( that is NOT COMMAS.)
ac7r3/xp
10 REPLIES 10
Djordje
Aussie wrote:
You will need to restart Archicad for it to work and it wont change any dimension already diplayed
If you want to update the existing dimensions, do something to them (add a node) and then edit them back to the original state (delete the added node) and it will update.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
