Tom wrote:
Any other ideas? Haven't heard anything back from GS support yet. Thanks Tom
I am not sure what to try next.
I have tried it with a default GS 'door 22' and created a custom door leaf with an override surface, with and with out a cover fill.
And it worked fine for me.
Just as a final check, make sure your schedules are all closed.
In the plan switch to the GO with the transparent background fills.
Now open the door schedule from the Project Map and not the View Map, so you can be sure you are not changing the GO.
