NStocks:
If I understand what you are trying to accomplish: you can place a view multiple times on a layout, and use the edit edge option on the pet palette of a selected drawing to move the boundary of the drawing. Also, you can change the scale of a selected drawing. So you could place the view once, select it, change the scale (so the section is larger), and edit the boundaries to show just the section (it is generally better to work on the drawing at the scale it will be printed due to WYSIWYG). The view can then be placed a second time for the elevation names. If this does not help, you should post more information about the issue.
