2009-02-10 11:39 PM - last edited on 2023-05-19 04:01 PM by Gordana Radonic
2009-02-11 12:04 AM
2009-02-11 08:39 AM
Hence wrote:If the above is really all you want, make an empty space in the title block on the master, and then simply type the date on the specific sheet with the text tool!
i could add a parameter to the title block that would allow me to enter text information (date) that would only show up on that specific sheet
2009-02-11 12:03 PM
2009-02-11 02:43 PM
Hence wrote:Place the <date> Autotext on the sheets where you need it. Same amount of work.
i could add a parameter to the title block that would allow me to enter text information (date) that would only show up on that specific sheet and not everywhere else.
2009-02-11 03:04 PM
2009-02-12 12:54 AM
2009-02-17 12:46 AM
Thomas wrote:x2Hence wrote:If the above is really all you want, make an empty space in the title block on the master, and then simply type the date on the specific sheet with the text tool!
2018-12-07 03:18 AM
