Tuesday - last edited Tuesday by Barry Kelly
i added the dimensions in archhicad. now i want to remove the comma and want to enable rounding in the dimensions. and want to remove commas
these are my dimension settings
Tuesday
That comma is your thousand separator in your operating system settings (if you change that you will have to re-start Archicad I think to see the change).
You can only set the dimension units and extra decimal precision.
You can not round dimensions, only choose a larger unit - centimeter, decimeter, meter.
