2008-06-22
		01:34 AM
		2025-02-07
		03:06 PM
			Aruzhan Ilaikova
2008-06-23 09:09 PM
ericyang wrote:I don't know which Object you are using, but most Stair Objects have a parameters called `Top Tread` that should be set to `Top Tread Below Floor Level` for that extra line not to display in 2D.
Does anyone know how to remove the toppest tread by using the stair library? if not removed the toppest tread will show on the upper floor 2D plan, which means there is a line shown on the plan.
ericyang
