2011-08-25 12:15 AM - last edited on 2023-05-18 05:39 PM by Gordana Radonic
2011-08-28 11:39 PM
2011-09-16 09:21 PM
2011-09-21 01:20 AM
Sergio wrote:Are you printing from a "Publisher Set" ?
Actually I have a similar problem with the designjet 110. I can not print custom size paper. The print window says that this sizes are not supported. The 110 has been a real pain so far.
2011-09-21 01:33 AM
2011-09-21 01:48 AM
2011-09-21 01:59 AM
2011-09-21 02:17 AM
2011-09-23 12:25 PM
2011-10-28 09:29 AM
VMG wrote:Back to the original post.... If you set the "Format For" pulldown to "Any Printer"... you should be able to select any paper size.
I have a problem in archicad v.13
My printer is an HP DesignJet 110 and when I try to change the size A4 to A1, the options are impossible to select.
