images in scale
i want to import a scanned image into my drawing, how can i make it to be in right scale, if i want to draw over it in actual dimensions.
5 Replies 5
Djordje
http://archicad-talk.graphisoft.com/viewtopic.php?p=35092#35092
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
hvala
shello wrote:
hvala
I would also suggest that you look at this post:
http://archicad-talk.graphisoft.com/viewtopic.php?p=31441#31441
woodster
Here is my simple good old trick. You have to know the distance (as long as possible) between two points in the scanned picture. Paste it into the plan somewhere, don’t pay any attention to resolutions, scale measures etc. Draw a line from point A to B. Zoom in to gain accuracy on both ends. Select both the picture and the line. Go to Edit>Resize..., tick “define graphically”, then <OK>, click on point A, then click on point B, leave cursor on point B, hit “r”, type in the known distance and hit <enter>. So now you have your plan picture in correct scale. Delete the ref line, place the picture in desired position and angle and you’re done it.
Djordje
shello wrote:
hvala
Nema na čemu
Djordje
HP Omen
