inactive output scale
Which could be the reason that the output scale in PlotMaker 8.1drawing attributes is inactiv ?
4 REPLIES 4
__archiben
ede
with archiCAD 8.1 you now have the option (back) to control scale, pens and layers within plotmaker, or have archiCAD's settings override you on each update.
see here for discussion:
http://www.graphisoft.com/community/archicad-talk/viewtopic.php?p=4513&highlight=scale#4513
this has come up quite regularly if my memory serves me correctly - you are not the only one to ask!
~/archiben
b e n f r o s t
Djordje
It is active if it is Autotext placed in the Title or within the view in ArchiCAD. Yes, it would be good if you placed the Autotext in the titlebolck and, although it correctly shows 1:1 now, it could somehow read the scale of the placed drawings, and in the case of various scales says "as shown".
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I cannt get it to say annyting else than 1:1
I place the <OUTPUTSCALE> autotext in a layout book but i cannt get to write anything else tha 1:1
Only if i create an auto text for a special drawing but this is not what i am looking for. I was expecting the autotext to read the scale and put it there..
What am i missing?
Djordje
That is correct; the output scale of the layout book is 1:1
As I said - put it in the TITLE that is linked to a particular drawing. If it is in the title block, it is not linked to the drawing and references the overall scale of the layout book.
Djordje
HP Omen
