interior elevations are not creating layouts
Greetings. For some reason my interior elevations are not creating layouts in the layout book. My exterior elevations do this effectively. Please help.
4 Replies 4
David Maudlin
bobup:
You should describe the method you are using for placing Views on Layout sheets for both the Interior and Exterior Elevations, it will help explain your issue.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, I looked at the signature issue and believe that has been corrected. The layout book on 'navigator' seems to automatically create layout sheets for plans and exterior elevations without me having to do anything extra. However, after using the interior elevation command and viewing the interior elevations that were automatically generated, I expected to see interior elevation sheets in the layout book. They do not show up as expected.
I am temporarily putting interior views on an unused exterior layout sheet just to get something to the client. This is not acceptable in the long run.
Hope this is enough info.
Thanks, Roy.
Found my answers on interior and all elevations. Thanks for viewing this post.
Roy
nusha
Roy
Hi!
I have the same problem... Could you let me know how you solved it?
