issues with exporting to pdf
helle
Did anyone have ever experienced that archicad only creates pdf files with 0Bytes? I've tried to export a line drawing but every time I save it as a pdf file and try to open the pdf, it says:
"Adobe Acrobat could not open "name.pdf" because either the file type is not supported or the file is corrupt (e.g. an incorrectly decoded e-mail attachment).
To create an Adobe PDF document, switch to the original application. Then select "Save as Adobe PDF" from the PDF drop-down menu in the print dialog."
1 REPLY 1
lopezfigueroa
Hi Helle.
Try Using the publisher
And reducing the size of the output name
