labels
Hi!
I am trying to set wall, slab, column and beam labels.
What I struggle with is the size.
When I set labels for each of those elements labels are applied as defined, but only thing that I haven't found is how to determine size of it.
I have attached a picture with that problem. You will see how those automatic labels work. I would like to get label like in red circle. That one I have set manually.
Is there any possible way to define size of labels?
6 REPLIES 6
Erika Epstein
Once the automatic labels are showing, as in your screenshot, activate the label tool and select all the labels cmd/ctrl + A.
Now in the label settings you can change them to your desired settings.
A Tip is to then save your settings as a favorite.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thank you Erika for your fast response, but I see that you didn't understand me.
Only thing that I can change the way you described is arrow head. My problem is the size of the marker.
Automatic are to big. I would like to have it as big as the one in red circle.
other thing is I need label to have line that goes over whole wall. Automatic labels point reference line so sometimes they go over whole wall but sometimes not.
Erika Epstein
Mzex,
I did not misunderstand. Follow my instructions and also take a look at how to manipulate a label in the AC help file.
I took automatic wall label on the right and edited it to like the one on the left which mimics your request.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
well I am looking into help and into settings, but there is no explanation of how to change length of label lines that could apply to all labels in project.
can you explain the procedure what you did? (step by step)
my question does not go for arrowhead nor frame around text. I know how to change those by selecting them all. I wonder how to automatically change sizes of all wall labels in project or to get them in desired size before placing them. I am not interest in changing them manually on floor plan because I know how to do that and when having them more than one that is not possible to be done in only few clicks.
so is there a way to get those wall labels smaller by default?
I am not interested in changing arrowhead. Just to be smaller. And I am not satisfied to manually change one by one.
As on jpgs attached in this message.
label.jpg shows what I get by default.
label 2.jpg shows what I want to get.
By default labels are too big especially if I go into 1:50 scale.
