2024-04-09
08:27 PM
2024-04-16
11:51 PM
I don't know why when I draw a line or polygon line, the dimension is way off. But if I draw a polygon box, then the dimension is correct. When I use the measuring tool is correct as well.
Operating system used: Mac Intel-based Sonoma 14.4
2024-04-10 03:49 AM
It seems to be reading the values from the project origin/
But I have no idea why that is different when drawing a polygon or using the measure tool.
The only setting I know of is...
Try turning that off/on.
You will see a line tracking back to project origin when you turn it off, so I don't think it is that as I don't see it in your images.
And again it would be the same for all tools.
