dhnguyen
line thickness
Please see image below: Both of these lines are designated to the same pen setting color (32), how come one has a different thickness than the other? For this color, I designated it to be .18mm thick.
Whether I drew them as single line or polyline, they show up as thicker than the other line., How do I make them the same?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Reply 1
You might be using the "Cut Line" category instead of a "drafting line".
More information here:
https://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/documentation/drafting/lines/line_categories_in_archicad/
Jono.
