line weight help!
hi!
i use archicad 12, and i lost my line weight option when im in drafting mode! i use the line tool, and when go to the color palette to change the color, it used to give me an option to change my black lineweights. anybody know how to get it back???
the picture is of the palette i have now. my old palette used to have 5 or 6 black boxes at the bottom to choose from with different line weights.
Thomas Holm
Try looking in Help for Pen Sets.
perfect!! thanks
Thomas Holm
laylool wrote:
perfect!! thanks
No problem. Archicad's help files are quite good. And context-sensitive - if you for example are doing what your picture shows, a right-click will give you Help on the subject directly without searching.
