line weights on opposing faces of the wall object
hi; wondering if there's a way of adjusting the weight of lines on either side of a wall object. i would think it possible since each wall is placed as a vector;
Archicad V9
thanks
3 Replies 3
nb
You can use a single skin composite wall with different pens on each face. Be sure to check the "Composite's separator lines" in wall settings.
ah; thanks Stuart. further question though; i see in the wall settings dialogue box where i would check the 'composite's seperator lines', but they are greyed out, i don't have the option to select. i apologize as it is probably really obvious, how one enables a composite wall; i'm only a couple weeks into this program, thanks.
ned
tulane school of architecture
www.edwardmonro.com (under construction)
awesome; fig'd it out, answer to my question (for anyone else wondering) was you simply choose a composite fill from the wall settings dialogue box, and this enables you to treat the line weights seperately. thanks again;
