ontwerpburowilzing
Image Issue when Publising to pdf
I recently started using archicad and when i have imported images in my projects they seem to publish rather weird.
I have tried importing the images into my layout as png/jpgs but when i export and publish the file as an pdf they come out with weird visual bugs.
This only happens to images and not with lines in my layout.
Schermafbeelding 2025-01-22 105048.pngSchermafbeelding 2025-01-22 104924.png
rgarand
Try adjusting "Document Options" on the PDF within the Publisher Set. Then click "PDF Options". Then increase dpi. Not sure if this will solve your problem, but it may help to improve the output slightly.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
