Pen Weights
I have assigned different pen weights to each object however when I plot/print all the lines print as a single thickness. Is there some way to enable pen weights when printing? Or is this a printer setup issue?
I assigned pen weights in ArchiCad only. These weights do not print from archicad or plot maker however. I have tried printing to two different printers and a plotter. Specifically, I would like to print my floor plan from archicad to my HP 9650 printer. I set the printer to greyscale but can't find any settings related to line weight.
3 Replies 3
Stig Bengtsson
Some printers print "true weight" only if you have "true weight" set in your display options.
Stig
Architect AIA RIBA SAR/MSA, Graphisoft Registered Consultant
AC19 SWE 7006
AC20 SWE 4012
Bruce
Remember, there are three places you can set your pen weights:
1. In ArchiCAD
2. In the PlotMaker Book
3. In each PlotMaker Drawing.
Also check your printer settings carefully - they can have an obscure option like "print all lines as hairlines" or something.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
You will get better answers if you give more info. What printer (or plotter)? Printing from AC or PM? System & software versions are also helpful.
